keshavdsd
Today I configured ads on AMP page from ADInserter wordpress plugin. After the implementation of AMP ads, AMP website’s layout has been shifted left. A small margin showing in the left on mobile. You can check screenshot here. Shifted layout mark in red color in the screenshot.
Problem occur on all post pages, Sample URL: https://celebritate.com/celebrity/nithin-gopi/amp/Thanks,
Keshav -
Hi Keshav,
There’s nothing on the theme that could cause that. You would need to check the settings on AdInserter or the advert you’re loading to correct that.
keshavdsd
I have checked everything but there is no solution found yet.
Can you suggest any solution?
The width of the AMP ads is coming from the Ad itself, not GP. Do they have support for these ads? You’ll need to check if there’s a way to alter the width so that it doesn’t overflow.
keshavdsd
I think this problem is of adinserter plugin, and some reason is also adsense. But no correct answer is coming from the support of both.
I have also tried setting the width of the ad code as directed by adinserter support but no solution was found. -
unfortunately is impossible for us to debug that issue as the overflow may be related to a specific advert, how the adinserter inserts them or the AMP template/CSS. Theres just too many variables and no consistent example of the issue for us to advise on.
keshavdsd
Okay Thank you..
You’re welcome
