One last questions. Is it correct, that you cannot hover over each menu-name and each mega-menu opens instantly?
For example, when I hover/click the 1st top-level menu, the mega menu opens. Now, when hover/click the 2nd top-level menu you can not click it. I need go away from the navi-area with my mouse, then I can click and open the 2nd top-level menu.
I guess this is something which would need further development as you mentioned before.
Thank you again David! -
The mega menu should not interfere with the behaviour of the menu itself.
If the focus is remaining on the 1st item you open then, i assume the menu content is somehow overlapping the primary navigation.If you can share a link to the sit where i can see the issue i may be able to advise
“overlapping” was the keyword. I added some CSS. Now its fine. Thank you again David!
You’re welcome
Anonymous
I have follow a instruction but did’t worked for me. Please help me I am not good at coding
I have create a topic and also added login details.https://generate.support/topic/need-argent-help-with-mega-menu/
gunrose2003
Yes
