I hope to get a quick opinion on this one as digging through the forums and docs didn’t get me further.
On my site, I am using the blog setting for the front page, so on my front page, the most recent posts are shown. I am using a custom Block template to style the “loop” and a custom layout to have a sidebar appear to its right.
However, on the top of the page I want to show the most recent articles in a highlighted format, as shown in my mockup. This setup might also change based on device, so it might be fairly complex but I know it is achievable with the block editor.
My question is
1. How to I hook in this custom styled block to my blog front page?
2. How can I set an offset in the loop below, so the articles shown in the top block do not appear in the loop again. I know there is an offset setting in the “Query Loop” block, but as I am using a Content Template, I am not sure to achieve this.Thanks for some help!
1. Just create a Block Element – Page Hero for this: https://share.zight.com/bLuQxAxX
This would consist of 2 Query Loops.
2. You can add a snippet like this:
function custom_offset_posts( $query ) { // Check if it's the main query and if it's the blog page if ( $query->is_main_query() && $query->is_home() ) { // Set the offset value (adjust as needed) $offset = 5; // Change this to your desired offset // Modify the query to include the offset $query->set( 'offset', $offset ); } } add_action( 'pre_get_posts', 'custom_offset_posts' );
Thanks Fernando for this fast reply. Technically, this works perfectly.
Regarding the CSS styling, I am having problems to customise the typography of the page hero block. E.g. the default h2 styling rules seem to overwrite the settings I do in the block editor. Is that a normal behaviour?
can i see the page where the styles are being overwritten?
Hi David, sure. I have attached the URL below.
In the top element you see on this page, I have for example set a font weight of 700 & font-size: 3rem in the block editor for the h2 class
gb-headline gb-headline-0d139cc1 gb-headline-text
But in the frontend, the global h2 style is applied.
Duplicate the problem headline block and delete the original
It will re-generate the unique CSS ID for that block.This kinda of thing can happen if you copy blocks between posts, eg. from a post to an element, they end up with the same ID and the last block on the page to load will get the dibs on the CSS.
Ah, got it. Thank you!
you’re welcome
