I want to create a custom blog layout page but every tutorial that I see on Youtube is using CSS to edit.
I do not understand CSS well.
Is there any other way to setup things like editing the read more button?
you can use the Block Editor and GenerateBlocks to create a Block Element – Content Template, see here:
https://docs.generatepress.com/article/block-element-content-template/
That element comes with some prebuilt templates to choose from.
Then you can visually edit your blog post design -
Will I be able to create a custom layout?
Yes – Have you taken a look at the documentation and the videos at the bottom?
https://docs.generatepress.com/article/block-element-content-template/#examples
