dana8550
Just since updating GenerateBlocks, I have experienced the following problems with a 2 year-old website:
*The site is not responsive in the hero banner and with a plugin called Easy Image Collage
*The ‘Portfolio’ dropdown menu on mobile and Safari desktop isn’t working
*The ‘return-to-the-top’ carrot does not appear in Safari desktop, but it does appear on desktop in Chrome
*While tinkering with it, I encountered the white screen of death, although that issue is rectified for now, I’m worried the problem will come back again.I cleared the cache in WordPress, Chrome, and Safari. I did not deactivate the Easy Image Collage plugin as I was afraid of losing all that work.
Thanks, in advance, for your help.
can you try purging the SG Optimiser caches and any page caching you have on the server ?
As it’s most likely a cached code issue.Let me know.
dana8550
Thanks for your response. I emptied the cache on SiteGround. It did not rectify any of the issues. The collage plugin hasn’t been updated for a month. I wonder if it’s a compatibility issue.
For reference, i see errors relating to a SG Optimizer cached file in the browser developers tools.
Can you disable the SG Optimizer so i can take a closer look? -
dana8550
Okay, it appears all the issues are resolved when the SG Optimizer plugin is deactivated.
So SG will have cached the optimized code, and it may just have required those caches to be cleared, which can sometimes take a few attempts.
Re-activate the SG Optimizer and purge its caches, and purge any page caching on the server.
If the issue continues then a setting in the optimizer needs adjusting. It will be one of the CSS optimizations, to debug which one , disable them one at a time and purge the caches to see if its the issue. -
dana8550
Thanks so much David. In addition to the caching and CSS issues, there was also a problem with the feature ‘Combine Javascript Files,’ limiting the number of executions. All is well now. Thanks again.
