jdroland
How do you change the icon color on a button that is different from the text button color?
https://postimg.cc/DJcH6fpb -
Any chance you can link us to the page in question?
You can use the private information field.
Let me know π
jdroland
Francisco
You can change the button icon color by clicking your button in the back-end and then in the right sidebar go to Block -> Advanced and inside the ADDITIONAL CSS CLASS(ES) field, add a custom class like, for example,
custom-color
.Then, you can add custom CSS code to alter the
fill
value, even for hover:/* CSS to change the fill color */ .custom-color > .gb-icon > svg > path { fill: red; /* Replace 'red' with your desired color */ } /* CSS for hover effect */ .custom-color:hover > .gb-icon > svg > path { fill: blue; /* Replace 'blue' with the desired hover color */ }
Reference: https://docs.generatepress.com/article/adding-css/.
Side note: There’s also feature request for this already. I’ll add a +1 for you so that it increases in priority of our Feature Request list.
Let us know how it goes π Thanks!
jdroland
Thank you
Hi Francisco – Please upvote this feature from me too. Anytime you can move CSS like this to the editor makes sense – especially when using Global Styles.
To link the color to the GP color palette, give this CSS a whirl. The variable color can be linked to whatever palette color desired, and it now has more global styling capabilities.
/* CSS to change the fill color */ .custom-color > .gb-icon > svg > path { fill: var(--primary-accent); /* Replace 'primary-accent' with your desired palette color */ } /* CSS for hover effect */ .custom-color:hover > .gb-icon > svg > path { fill: var(--secondary-accent); /* Replace 'secondary-accent' with your desired palette color */ }
Thanks,
David -
Francisco
You’re welcome, jdroland! π
Hi David, I’ve already added your +1 as well. Thank you! π
