OSUREN
how can i make buttons the same size, when im using different word in theme…i need all sizes to match
so fixed width buttons
Did you mean to set a fixed-width button globally on your site? If so, you can use this CSS:
button { width: 150px; /* Set the desired width, such as 150 pixels */ }
OSUREN
Here’s the images of the issue, and thanks you for everything you do!
You can set a fixed width for the buttons and just ensure it’s fine for mobile view as well.
OSUREN
how? i cant find that area…can you show via screen shot
Select your button block, then on the Sizing setting on the right-hand side, you will find the width setting.
OSUREN
thank you very much!
You are welcome!
