Health Blogger
I have two issues.
Issue 1:
I am using a Hero pattern from the GB library, I have changed the background image but am unable to adjust the location of H1. I would like the H1 to be lower, closer to the bottom. How do I set it to the level I want? https://ear-guru.com/hearing-aids/ . https://ear-guru.com/speech-therapy/
Issue 2:
I have used the Button container, but do not see the usual typography and color setting options for the individual buttons? The button takes the default colors. I would like a different background, text and hover colors for the “Read more” button, not the default colors. See the section below the Hero image, https://ear-guru.com/
Thanks,
Amrik
fernandoazarcon2
Hi Amrik,
#1 Remove the bottom padding of the Container Block holding the Headline. Set the top padding to 180px.
#2 You used a WordPress Button Block. Replace that with a GB Button Block instead.
Health Blogger
Hi Fernando,
Resolved the H1 issue, though the top part of the image cuts off. How do I retain the top part and let the bottom cut off? It looks fine on Mobile, the issue is only with desktop. https://ear-guru.com/hearing-aids/
Issue 2:
I am unable to get the GB Button Block, what am I doing wrong? This is all I see. https://prnt.sc/r-WrawTzMRUU
Regards,
Amrik
fernandoazarcon2
#1 Try setting the background position to
top center
.#2 The
Button
in your screenshot is the one from GB. -
Health Blogger
#1 – Sorted, Thanks.
#2. I am confused.
This is all I see. https://prnt.sc/qIP2mAJ9UBjb
I also searched and read https://docs.generateblocks.com/article/button-overview/#components-available but it’s of no help.
fernandoazarcon2
#2 That’s not the GB Button Block.
Can you share admin login credentials through the Private Information field? I’ll check if it’s there.
Health Blogger
Login details in the private info field
fernandoazarcon2
I was able to see it. This one: https://share.getcloudapp.com/6quJKQX7
The Button settings are also there when I tried adding one.
Health Blogger
Thanks, I had to key in Generateblocks to get the GB button, does not show up if I key in Button.
fernandoazarcon2
You’re welcome, Amrik!
