gvidano
Hello
I created my whole website using the “buttons” block and now this block is not available…
I am talking about the one as you can see on this screenshot:
https://svpremier.com/wp-content/uploads/2024/04/Screenshot-2024-04-18-at-1.18.04-PM.pngOnly “button” block is now available and there is also a “buttons” block available but does not seem to be the same as it used to be, different options, it is all different.
https://svpremier.com/wp-content/uploads/2024/04/Screenshot-2024-04-18-at-1.37.57-PM.png
What happened to the “buttons” block that used to be available? Does it mean I need to recreate all my thousands of buttons in my website using the new block?
gvidano
I read this but cannot figure out how to add a “buttons container” to my buttons like instructed here:
https://docs.generateblocks.com/article/button-overview/has this been deprecated too?
You can select the button, and click the add to container button to wrap a container outside the button blocks.
There isn’t a buttons block anymore since GB 1.7, it’s not just a container block.
gvidano
I just dont understand how to make it work using the new container.
The screenshot below for example has a set of buttons wrapped on the old “buttons” container (two row with two buttons on each) and right above it, it has the same buttons but wrapped on a regular container set to FLEX and WRAP
However, the display on mobile is totally different as you can see using the new container, it creates 4 rows.https://svpremier.com/wp-content/uploads/2024/04/IMG_0481.png
How Can I get the buttons to be more like the old way to display them?
The buttons I am testing on the following page you can find them:
https://svpremier.com/test-buttons/Thanks for your help
gvidano
I moved them to this page where you can test them:
You can use the Grid Block and choose the 4-column layout, then add the buttons inside the columns.
To achieve the old layout on mobile as shown in the screenshot you provided – in the mobile view editor, click the container inside the Grid block. Go to Block Settings and set the Grid Item Width to 50%. Apply the same setting for the other containers inside the Grid block.
