Kristen Hubert
Hi I want to use a hook to put an email sign up form part way through the body of my post content – e.g. 3-5 paragraphs in for example or after the second H2 or something like that.
Is there a way to do that? I can’t find a location like that in any of the hook options.
Hooks only exist in code, they aren’t inside your content.
But it is possible to create a custom hook after X number of paragraphs.
Here is the require PHP to create the Hook:add_filter( 'the_content', 'db_insert_portable_hook_two', 20 ); function db_insert_portable_hook_two( $content ) { if ( is_single() && ! is_admin() ) { global $post; ob_start(); do_action('inside_post_content'); $inserted_hook = ob_get_clean(); return prefix_insert_after_paragraph( $inserted_hook, 3, $content ); } return $content; } function prefix_insert_after_paragraph( $insertion, $paragraph_id, $content ) { $closing_p = '</p>'; $paragraphs = explode( $closing_p, $content ); foreach ($paragraphs as $index => $paragraph) { if ( trim( $paragraph ) ) { $paragraphs[$index] .= $closing_p; } if ( $paragraph_id == $index + 1 ) { $paragraphs[$index] .= $insertion; } } return implode( '', $paragraphs ); }
This line:
the3
specifies the paragraph number after to insert it.Then you can creata a block Element and in the Hook list choose:
Custom Hook
and paste:inside_post_content
in the field ( thats the hook the code provides ).
