Carlos
Is it me or I can’t seem to select different background colours for each tab button?
After setting the background colour for the first tab, I go change the second tab and all tabs changed in sync!
Surely there must be a way and it’s just too early in the morning for my brain to function, but I can;t seem to get it going, help!
You would need a custom CSS. Try this:
.gb-container-08e02125 button:nth-child(1) { background-color: white; } .gb-container-08e02125 button:nth-child(2) { background-color: red; } .gb-container-08e02125 button:nth-child(3) { background-color: orange; } .gb-container-08e02125 button:nth-child(4) { background-color: blue; } .gb-container-08e02125 button:nth-child(5) { background-color: green; }
Adjust the
background-color
value according to your preference. -
Carlos
Ah, OK, yeah, I can use css to fix this, however, using the GB interface would be way more easier and the settings are there, I just don’t get why are they all linked!
For example, in my view, it makes no sense at all that I can set each tab button with its own icon, but can’t set a background colour!
You guys need to fix this.
Carlos
Hi Alvind,
I implemented your solution, however, when the Tabs load the first time, the first tab comes up with the Background Colour assigned and not in the Active Tab state!
How do I go about fixing that?
I would also like that on a:hover the Tab Button Colours would invert, where’s currently the background stay the same (hover should be white).
Add this CSS for the active and hover state:
.gb-container-08e02125 .gb-block-is-current { background-color: white !important; } .gb-container-08e02125 button:hover { background-color: white !important; }
Regarding the ability to set a different color for tab buttons, it’s something we’re going to improve in a future version. Thank you for your feedback!
Carlos
Hi Alvind,
Thanks that sorted the issue.
Cheers
You’re welcome!
