mindyjoy
Hello, I am unable to disable page or post titles using the Disable Elements box on individual pages. All the other elements are able to be disabled but not Content Title. Is there a way to troubleshoot this?
The elements under the admin bar are:
Footer (Hook)
Merge (Header)
Global (Page Hero)
Google Analytics (Hook)Please let me know if anything else is needed to look into this. Thank you.
Does that mean that even when you’re checking the Content Title option, the title is still appearing? That shouldn’t be happening.
If that’s the case, we may need to check the settings on the backend. Could you provide a temporary login credentials if possible?
mindyjoy
Yes that is correct. I’ll put it in the private note.
the Element:
Global (Page Hero)
is whats displaying the title on that page.
And the Disable Elements won’t remove that, it will only remove the default page title ( which has already been removed by the Page Hero ) .Where you need to remove the title, you would need to exclude those pages from the
Global (Page Hero)
Display Rules. -
mindyjoy
When I exclude the Page from Global (Page Hero) it ruins the formatting. How do I just remove the title but keep the formatting? Examples in private info.
So basically you just want to keep the shape without the title?
If so you would need to create a separate page hero which is the same as the Global page hero and without the title then apply it to the
/quiz-result-great/
page. -
mindyjoy
Okay great, thanks for the help!
No problem 🙂
