I know it’s something I’ve done but I absolutely can’t change the body background color on the individual blog posts; the color set in customizer for body background is not applied to individual blog posts and I can’t figure out where the gray body background color is originating on the blog posts
https://pixelhappy.co/from-raw-to-real/
Can you help me track this down?
Go to Customizer > Colors and check the Body and Content background colors.
What are those set to ? -
Body is set to white as well as the content:
Inside your theme’s style.css you have this code added:
body.single.single-post, body.single.single-post { background-color: #f5f8fc; }
Remove that code as it overrides the color set in the customizer.
Well that’s crazy; I’ve looked in my custom CSS and can’t find this anywhere! I’ll keep looking.
Thank you.
It was located inside your child theme’s stylesheet. Go to Appearance > Theme File Editor to edit the stylesheet.
Found it — thank you!
You’re welcome!
