i tried to import tempalte from the site library to start my wordpress e-commerce site. BUt when i tried to import or select a template from the site library the animated “importing content” just keeps going for hours. i tried to refresh and no content are imported. tried restoring by removing the template and the animated still keeps going. What could be the problem? i also noticed the layout are broken.
Try to meet the server setting recommended here:
https://docs.generatepress.com/article/error-codes-importing/And also make sure all plugins except GP Premium are deactivated before the importing process.
on what file to set these? wp_config?
upload_max_filesize (256M)
max_input_time (300)
memory_limit (256M)
max_execution_time (300)
post_max_size (512M)im running nginx. on what server file to set?
fastcgi_buffers 16 16k;
fastcgi_buffer_size 32k;Please be specific.
already updated the php.ini
upload_max_filesize=256M
max_input_time=300
memory_limit=256M
max_execution_time=300
post_max_size=512Mbut upon site import the “importing content” is still on-going , the animation loading is still on-going so i never know if the import is successfull or not.
never touched the nginx server settings.
what do you think?
hoping to get help ASAP. Thanks!
site i want to import is “target”, other sites not on e-commerce “spacios” works!
at a minimum i would recommend this:
PHP max input variables 4000 PHP time limit 1200 PHP memory limit 512M + Max input time 600 Upload max filesize 300M PHP post max size 1000M
as its a Woocommrce site, i you will want to consider a higher
PHP memory limit
if possible -
what’s this? to add to php.ini? can you send actual variables because im sure what you sent will generate more errors. do we need underscore _ characters in between?
Can you please be more specific to prevent wasting time?
Thank you!
also, im running nginx. on what server file to set?
fastcgi_buffer_size 32k;Thanks in advance!
If you do not know how to configure the server, please contact your host, they know what that means.
hello,
i bought yesterday. i need a refund. i’m having a hard time using your theme. try importing and always failed. what i need is a theme that can easily customize and almost ready to run for an e-commerce news site. thank you!
We offer 30 day money back guarantee, you can open an Account/Billing issue here and our account team will help with the refund: https://generatepress.com/support/
