EasyMode
Hello!
I don’t know why all these pages doesn’t have any margin right and left in mobile devices by default. Should i add any extra CSS code or maybe i have to activate something? I attached some screenshot.
https://i.postimg.cc/8PZGyHqb/Captura.png
https://i.postimg.cc/gJW1cXCJ/Captura2.pngMany thanks!
Can you link us to the pages in question?
EasyMode
Hello! Yes:
https://bibiebibo.es/tienda/Thanks a lot!
It looks like you created the layout using Elementor. Have you set content padding on those pages that have no side padding?
EasyMode
Yes!
Because if I use the Theme layout, I cannot takeout the sidebar.
Can you tell me how to hide the sidebar whith the theme layout?Thanks
the checkout, cart and accounts are treated as static Pages.
And the Theme will apply theSidebar Layout
that is set in Customizer > Layout > Sidebars.
You can remove the sidebar from ALL Pages by setting it toContent ( no sidebars )
If you want to only remove the sidebar from those Woo pages, and keep it on other static Pages.
Then instead you can use a Layout Element.Go to Appearance > Elements -> Add NEw –> Layout.
In the Sidebar Panel chooseContent ( no sidebars )
Then set the Display Rules Locations to the specific pages you want to remove it from. -
EasyMode
thank you!
You’re welcome
