afuente
hello,
i´m not able to center a container with it´s gallery. I tried block, inline, flex everything.
Maybe you could have a look….
The url is https://www.casajavier.com/galeria
there are currently a redirection for not loged in users….
select the inner Container Block.
In Spacing -> Left Margin & Right Margin type:
auto
In Sizing -> Max Width set a value eg. 1000px -
afuente
hello,
thanks for your reply.
The max width propety doesn´t work, at least in this case… i have to use the width property….
That’s odd.
max-width
should work. Can you explain a bit more about what happens when you add a max-width as opposed to a width?Take note that if you add width, you need to consider the width for tablet and mobile as well so that your Block doesn’t go over the screen.
afuente
nothing happens when I add max-width…
Can you leave the edit page temporarily? I’ll check what’s happening. Set the max-width and leave the width setting empty.
afuente
sorry, sure. i leaved 😉 you can also force to enter. you can not damage nothing 😉
Can you set a max-width value first?: https://share.getcloudapp.com/d5ugDnZz
Also, are you able to access this page? I’m not able to access the page on the front end.
afuente
I did it already and it didn´t work. Thats why I set the width value….
To access to the front end, mayby the cache of your browser. (https://www.casajavier.com/galeria)
The front end is only accesible if you are logged in…. -
I see. Set the Parent Container to display: block. Then, set the max-width as opposed to just width. That should work.
afuente
ok. great. thanks;-)
afuente
great. it works. one question: would it be possible to create a similar gallery with generateblocks, including the lightbox popup?
GenerateBlocks has no lightbox, so you would need a plugin for that, so best to use a gallery plugin that supports that
