apinajus
I’d like to style the search bar as in the example below:
https://codepen.io/kennethjmyers/pen/ZWmNdMCould you tell me how to achieve this?
can you share a link to your site so i can see the search bar ?
apinajus
I’m not exactly sure what you meant by center it.
Also, we’ve introduced the Search Modal option to replace the previous Navigation Search option:
https://generatepress.com/generatepress-3-3-0/The new feature is much better for accessibility.
Would you consider using that instead? If so simply disable the Navigation Search option in the customizer then the Search Modal option should appear.
Let me know π
apinajus
Oh, awesome, this is more practical than before! π
Do I have any options to customize it a little bit?
I am trying to achieve this look: https://imgur.com/a/GIga2COThanks!
You can create a block element – search modal.
In that element, you can build your desired search modal and it will replace the default one π
