philipperoussel
Hi Philippe,
What I would recommend is to install the GeneareteBlocks plugin and use that to add the Image within a Container so that you’d have options for its alignment.
Reference:
https://docs.generateblocks.com/article/image-overview/
https://docs.generateblocks.com/article/layout-options-overview/
https://docs.generateblocks.com/article/flexbox-alignment-matrix/Otherwise, you can add this CSS through Appearance > Customize > Additional CSS:
aside#custom_html-30 .textwidget.custom-html-widget { display: flex; justify-content: center; }
philipperoussel
Hi Fernando,
I should have better clarified that my issue is purely an html one since the image must be in a custom html widget (not an image widget since the image will not be centered there either).
you should be able to simply set the text-align of the widget like so:
.custom-html-widget { text-align: center; }
philipperoussel
Hi David,
It works. I presume that for an image widget, it would be:
.image-widget {
text-align: center;
}Right?
Off the top of my head, I could not say… I would need to inspect the widgets HTML for the class.
If you want to add an image widget to the site, I can take a look. -
philipperoussel
I tried the following:
.image-html-widget {
text-align: center;
}and
.image-widget {
text-align: center;
}Neither of these works. No big deal but it would be nice to be able to center an image in an image widget.
Can we see this image on your site?
philipperoussel
It’s the last widget in the right-hand column (an image widget).
Try this instead:
aside.widget_media_image { display: flex; justify-content: center; }
philipperoussel
Cool!
Glad that worked!
philipperoussel
The code given earlier works for PCs but not for mobile devices.
Thanks for your help again,
Philippe
Hi there
can you try clearing the browser caches on your mobile ?
philipperoussel
Hi David,
I did that on two different smartphones. It does not change anything.
Are you going to centre everything in the sidebar?
If so ; this CSS should suffice:.sidebar .widget { text-align: center; }
