krachtigewebsites
I am using the inbound theme for this site: https://q-moodz.nl/
I would like to change the blue color on the left and right site as you can see on the homepage. Please advise where to do this..
Many thanks,
Stefan -
Just edit the homepage, while in the block editor, select the top container. Then, in the block settings on the right-hand side, find the color setting under the Background option. You can adjust the color there.
krachtigewebsites
Hi Alvind,
Sorry it doesn’t work. I don’t see the blue/green background parts on the right and left sites showing up in the editor..
Is there another way to change the color?
Thanks,
Stefan -
Check this screenshot:https://app.screencast.com/nl8n0HV59GJnW
krachtigewebsites
Hi Ying, it’s not that, it’s this color on the right and left.
https://app.screencast.com/ve8NbJ0Hoo7j4
How can I change that, please give me the steps to follow..
Thanks,
Stefan -
It is the background gradient of the root container:
https://app.screencast.com/XT8uIDKowJ271If you can not find the option, please provide an admin login to your site so we can take screenshot from the page editor.
To add the credentials, please edit your first post on this topic, and add the info into the private info field. It will only be seen by the support team.
krachtigewebsites
Hi, I sent a private message. Can you reply that you have seen it? Hopefully you can help.
Thanks,
Stefan -
I got it, and here’s the screenshot, it’s pretty much the same as the one I shared before, the gradient is added to the root container:
https://app.screencast.com/Y49kuMJrS0nC4
