linden.almond9621
I am trying to use a query loop on my blog page to display the blog posts. I prefer the look over the default layout. I can’t figure out how to stop the default layout from showing under the query loop layout.
You need to disable the Loop Template that’s showing or edit it.
If you’re unsure of which Element it is, kindly share admin login credentials through the Private Information field.
linden.almond9621
Temp login added.
Could you turn the User provided into an Administrator?
linden.almond9621
Done
Could you re-activate/re-create your Loop Template? I’ll check what occurs.
linden.almond9621
I deleted the loop element from the blog page then added it again. It shows on the back end but it does not show on the live page. It’s still the default layout, single column.
Could you re-create it? I’ll cross-check from my end.
linden.almond9621
Sorry, I’m not sure what you are asking. The element is already on the page. I’m not sure what you mean by recreate it…
Oh.
You need to create a Block Element – Loop Template assigned to the Blog Page, and copy and paste the Blocks you created there.
Dynamic Pages like the one your Editing can’t be edited by editing the Page itself. A Loop or Content Template is needed.
Reference: https://docs.generatepress.com/article/block-element-loop-template/
linden.almond9621
Ok, I created the Block Element but it looks like you are editing the page so I cannot see if it worked.
linden.almond9621
Got it, thanks for all your help!
You’re welcome!
linden.almond9621
Resolved
