Change/Delete main image on “Wordsmith” template
    I can not figure out how to change/delete the main image of the ponytail guy with feet on railing in the “Wordsmith” template in WordPress. Any advice is greatly appreciated. Thanks!
    edit the home page, and in the block editor, select the top most Container Block, in the block settings Background tab you can change the image there
