XHAUER
We have several widget on our homepage https://journal.xhauer.com/ (on the right side). One of them is called “LinkedIn Training”. Here you can see an image: https://i.postimg.cc/FK0gZ62s/XHAUER-widget.png
We have to the change the link the now is https://journal.xhauer.com/linkedin-formel/ and is forwarded to https://xhauer.com/linkedin-training/. I thought that changing it is possible in the menu “Design > Widget” or “Design > Customizer”. But unfortnately I don’t find where to change it. The new link should be https://xhauer.com/linkedin-training/?utm_source=Journal:utm_medium=organic.
Where in our backend can we change the link?
Thanks a lot and have a nice afternoon
Stephanie
that is a list of posts being displayed by the WP Show Posts plugin.
The list should be found in the Dashboard > WP Show Posts, can you see the list ? IF so you can edit the list and change which posts it displays. -
XHAUER
Hi David, thank you. Yes, I can see the list. I suppose it is “Sidebar”, right? But I can’t find the single posts that are displayed at the moment (B2B Podcast, Performance recruiting, LinkedIn Training).
The thing is, that I just want to change the link behind one of the displayed items – the LinkedIn Training Item. The rest can stay as it is.
Do you have another hint for me?
Thanks a lot!
Each of the WP Show Post lists has a shortcode provided in the list editor.
Does that lists shortcode match the shortcode in the Appearance > Widgets sidebar ?
If it does then that is the correct list.Edit the correct list
As it is showing a list of specific Pages, go to the More Settings tab and check thePost IDs
field
I would expect to see a list of the IDs for each page being displayed.
You need to update that list of IDs to include the pages you want to show. -
XHAUER
Alright, I will check this.
Thank you.
Let us know how you get on
