GeorgeB
I’d like the page background image to be visible in the containers with reduced opacity: https://drshernandez.com/?page_id=104&preview=true
Is this possible. I’m not well versed in CSS.
The linked doesn’t work for us as it requires a login.
Can you provide the direct link to the front end?
GeorgeB
Thanks Leo. Sorry! Here’s the page (very much under construction):
https://drshernandez.com/test-home-page-with-generateblocks/
I’ll provide the site login in the “Private info” dialogue.
Sorry what are you trying to change on that page?
These blocks here? https://www.screencast.com/t/gxcRuVxLqf
I don’t see any background images there.
GeorgeB
I should have explained better. There are no background images in the containers, just the waterfall in the GeneratePress page background. I’d like to have the waterfall show through as a low-opacity background for the containers.
I would then apply background images individually to the grid header and paragraph boxes. (Tropical foliage & flowers.)
GeorgeB
Here’s a screen grab as I’m seeing the page:
I’m still a bit confused but can you try adding this CSS and see if this is what you are after?
.one-container .container { background-color: rgba(255, 255, 255, 0.82); }
Learn how to add CSS: https://docs.generatepress.com/article/adding-css/
GeorgeB
Yes, that’s it exactly. Thanks very much. Alas, I think my brilliant idea, maybe wasn’t. 🙂 I’ll likely try something else.
No problem 🙂
GeorgeB
Very good to have the CSS!
