fmosse
Hi, In my website I have the secondary menu at the top. And the primary menu is at the right of the logo.
I would like to change the position of the secondary menu bellow the “inside-navigation grid-container”.
I know that I could disable the seconday menu and create an element in Appeareance > Elements, but if I do that I would loose all the configuration of Appeareance > Customize > Design > Seconday Menu.
Thanks,
Francisco -
Could you provide a link where I can see the page?
fmosse
Yes, I will put it in private.
In Customize > Layout > Secondary Navigation, what did you set in Navigation Location?
fmosse
Thanks, I am using that menu changing the position!
You’re welcome!
