Changing bullet points to icon on selected pages only
  • HI,
    Unfortunately I removed the chevron-right bullet point icons from one of the starter templates and I can’t get it back.
    Is there any way I can install an icon to change from standard dot points please?
    refer URL in the private info box.
    Seems like you’ve used the List block for the list. However, we don’t have control over changing the bullet points to something else.
    An alternative approach is to use a GenerateBlocks Headline block for each bullet point. This allows you to use the available icons provided or add your custom ones to the headline.
  • The headline suggestion is perfect. Thank you very much.
  • No problem, glad to be of help!
