schneiderpeeps
I want to install the Tasty child theme. I have the blank child them installed right now and that’s the only one I can figure out how to install. Can someone tell me how to get the Tasty download? thanks!
Tasty is a site from our Site Library.
They are NOT themes, they are just a prebuilt starter site you can import.This article explains how to install a site from the library:
https://docs.generatepress.com/article/using-the-site-library/
schneiderpeeps
Thank you!
You’re welcome
dmauder
@David – I just created a 2nd staging site to play around with and I’d like to import a site library template. I already have a bunch of content (site logo, images, headings, static front page, as well as posts & pages). I’d like for the site to look as close as possible to the template, so would you recommend I “Import Demo Content” and then do the necessary clean-up?
From the article you linked above:
Import Theme Options: This option will import the customizer options only and skip all the demo content and page content.
- Import Demo Content: This option will import the demo content.
If you want your site to look exactly like the template, then importing both theme options and demo content are required.
Based on that, I’m guessing the answer is yes, but I wanted to ask before I go down the rabbit hole. 😉
Yes, you should import demo content, as all GP elements are counted as demo content, and these are the important content for the site templates 🙂
dmauder
Thank you @Ying. I’m making MUCH better progress now by starting with a Site Library template and then doing content clean-up and modifications from there. It’s also helping me see & learn how to do certain things the “correct” way in GP/GB. 😊
