Benny
Hey there, i have a weird problem with the overlay. There is a link that leads to a specific section of a page. If i click it, it closes the overlay and scrolls to the section, but if i click again, after im still on the page, the overlay stays open.
You can test it here –> https://akademis-internatsberatung.de/
The Link is called “Partnerschulen”
Thank you!
thats an odd one… i wonder what the conflict is there.
If you disable the GP Smooth Scroll – does the issue still persist ? -
Benny
Tried it and doesnt work 🙁
Is there any other plugins / functions that alter Link behaviour ?
Benny
Hm, tested a newer site i built and there it works. Fuck, so i have to find the plugin causing this…
Thank you anyways!
OK, let us know what you find.
Benny
Hm, made a staging version, disabled all snippets and nearly all plugins and same problem. Tested something else. The other site where i worked, is a bit different. There i made the menu with the wordpress menu. On the page where it doesnt work, i made the menu purely with generateblocks. Maybe there is a difference (aria-current, some classes i have to apply)?
Benny
Fixed this by using a navigation block. Before i built this solely with generateblocks, but this works too. Maybe something to fix in future releases?
Thank you again David!
Hmmm…. ill do some tests to replicate the issue, and we’ll see what we can do.
Thanks for reporting, and glad to hear you found a solution.
