Andrea G.
Hello!
I need the containers of a grid to be same height even if the content is not the same. Link in pvt.
If you play around with the screen size on desktop the bottom of the containers gets disaligned.
Can you please help me? 🙂
You can refer to this documentation here:
https://docs.generateblocks.com/article/equal-height-grid-containers/ -
Andrea G.
Hi Alvind, that doesnt work.
1. select then first grid column container and remove the Sizing > Max Height property.
2. inside each column container is another Container block, select those and set the Height to 100%
3. select the button block container at the end of each of column and set the Spacing > Margin Top to
auto
Andrea G.
Done, but still not working! Can you please check?
Ok, some of you grid column Container Blocks are the Legacy containers.
You need to convert those:The notice will give you the option to change them WITH or WITHOUT a Inner Container.
Choose WiTHOUT the inner container. -
Andrea G.
great! Solved 🙂
Glad to hear that
