Hi there, I’ve created a blog page and added a quer loop to pull in the posts. When I try to create an element> content template> assign to all posts I am not seeing it being pulled through to the post page. Can you let me know what I’m doing wrong?
You added a query loop into the posts’ content template, why?
What do you want to show on the front end for the post?
Let me know ๐
Hi, No I didn’t add a query loop into the post content template. I added a query loop on the ‘blog’ page to pull in the posts. It is for the the actual content of the blog post I am struggling. I want to style what the post will look like. I added element> content template and set it to post>all posts but it is not pulling through.
I just want to style the blog post and have that layout display when someone clicks into the blogpost.
Thanks ๐
I don’t quite understand your settings and goals sorry.
You do have a query loop block in the content template which is assigned to posts > all posts, why do you add that?
https://app.screencast.com/GMrRjlAOklAPnI just want to style the blog post and have that layout display when someone clicks into the blogpost.
You can create content template for single posts, but you added a query loop block in the content template, that’s what I do not understand. I’m not sure what layout you are trying to achieve. Can you explain some more? Maybe with screenshots?
Oops sorry Ying. I must have done that within the content template without realising. I’ve deleted it.
Sure I’ve added a link to my own website where I’ve done this before. I just want to style the post page so when I create a post it goes into the same layout.
I get it now!
In this case, you just need to create the correct
block element - content template
, the locationposts >all posts
is correct.In your element, you can add a dynamic content block to present the post content.
And other things you want to show on a post.
That did it. I don’t know what I was doing lol. Thanks Ying!
Glad to hear that! You are welcome ย ๐
