lcwoffindin
I have some elements I want copy to another website.
The WordPress import/export does everything, it doesnt allow selection of each item to copy.
Is there a way to export just 2 elements and import?
LenW -
the WP import/export doesn’t provide any more granular controls for CPTs.
So unfortunately, it is ALL or nothing.
You can always delete the ones you don’t require from the imported site. -
lcwoffindin
David, thanks.
I have manually set them up on the live website, having set them up in a copy website.
With the block editor I used the copy all blocks function on the element, then in a separate browser window pasted into a blank paragraph block on the other website, all worked fine.
Then just set the element display options to match.
So in the end not too much time taken.
LenW -
Glad to hear that
lcwoffindin
Will you consider a GPress export / import for elements? That would be really helpful.
Apart from this, please consider this sorted and closed. -
