ashokvas
I am using GP PRO with GB Free version
I want to create FAQs block and enable the Schema
Can I do it? or do I need GB Pro version?
The Accordion block is a GB pro feature so yes you will need to the pro version:
https://docs.generateblocks.com/article/accordion-overview/
https://generateblocks.com/pro/I did quick search and found some useful resources for setting up schema:
https://youtu.be/NQbDk_WCJlE?si=N30mUqw4q3qPHYPl
https://bloggingidol.com/faq-section-with-schema-using-generateblocks/I hope this helps.
ashokvas
Can I use Kadence blocks or Stackable blocks for the FAQ section as they allow accordion in free versions.
The rest of my templates are built with GP Pro/ GB free
Will it clash if I use different block plugins?
Of course.
No.
