Alexis822
I would like to know how to make this section with generateblocks (private link of the section on Figma). Because the image on the right should change according to the accordion menu.
Because the filters at the top I can use tabs. However, for the text on the left with the changing image, I should have used vertical tabs, but this isn’t possible with the template.
it would take some custom work, not sure if i can assist here, but first off – the image, is a CSS background image an option or must it be an
<img>
block ?Just trying to assess the complexity and whether Javascript is required.
Alexis822
Yes in css I’d have to change the background and if it’s is it in js? I don’t know which is better
If it’s a background image, it might be doable with CSS.
Can you try this structure and add the highlighted text as the additional CSS class to the blocks?
https://app.screencast.com/hJTvmtaOqRNBxOnce that’s done we can take another look.
Alexis822
Ok it’s done
Theres a few hurdles to jump over here.
I would use this structure:https://app.screencast.com/ApDjxpVwjtstP
And here is the block HTML for that, you can switch the editor to the code editor, and paste it in and then return to the visual editor:
<!-- wp:generateblocks/container {"uniqueId":"afe61157","isDynamic":true,"blockVersion":4,"blockLabel":"Relative Parent","position":"relative"} --> <!-- wp:generateblocks/container {"uniqueId":"21677a7b","isDynamic":true,"blockVersion":4,"useGlobalMaxWidth":true,"spacing":{"marginRight":"auto","marginLeft":"auto"}} --> <!-- wp:generateblocks/container {"uniqueId":"4d9c0c19","isDynamic":true,"blockVersion":4,"variantRole":"accordion","sizing":{"width":"50%"},"accordionTransition":"slide"} --> <!-- wp:generateblocks/container {"uniqueId":"200de928","isDynamic":true,"blockVersion":4,"variantRole":"accordion-item","useTransition":true,"transitions":[{"state":"normal","target":"accordionContent","customSelector":"","timingFunction":"ease","delay":"","property":"max-height","duration":0.25}],"accordionItemOpen":true,"accordionTransition":"slide"} --> <!-- wp:generateblocks/button {"uniqueId":"4558ff5b","blockVersion":4,"variantRole":"accordion-toggle","buttonType":"button","display":"flex","alignItems":"center","justifyContent":"space-between","columnGap":"0.5em","sizing":{"width":"100%"},"typography":{"textAlign":"left"},"spacing":{"paddingTop":"15px","paddingRight":"20px","paddingBottom":"15px","paddingLeft":"20px"},"backgroundColor":"#ffffff","backgroundColorHover":"#ffffff","backgroundColorCurrent":"#fafafa","textColor":"#000000","textColorHover":"#222222","textColorCurrent":"#000000","hasIcon":true,"iconLocation":"right","iconPaddingRight":"","iconStyles":{"width":"0.8em","height":"0.8em"},"accordionItemOpen":true} --> <button class="gb-button gb-button-4558ff5b gb-accordion__toggle gb-block-is-current"><span class="gb-button-text">Accordion title</span><span class="gb-icon"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 448 512" width="1em" height="1em" ariahidden="true" role="img" class="gb-accordion__icon"><path d="M207.029 381.476L12.686 187.132c-9.373-9.373-9.373-24.569 0-33.941l22.667-22.667c9.357-9.357 24.522-9.375 33.901-.04L224 284.505l154.745-154.021c9.379-9.335 24.544-9.317 33.901.04l22.667 22.667c9.373 9.373 9.373 24.569 0 33.941L240.971 381.476c-9.373 9.372-24.569 9.372-33.942 0z" fill="currentColor"></path></svg><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 448 512" width="1em" height="1em" ariahidden="true" role="img" class="gb-accordion__icon-open"><path d="M240.971 130.524l194.343 194.343c9.373 9.373 9.373 24.569 0 33.941l-22.667 22.667c-9.357 9.357-24.522 9.375-33.901.04L224 227.495 69.255 381.516c-9.379 9.335-24.544 9.317-33.901-.04l-22.667-22.667c-9.373-9.373-9.373-24.569 0-33.941L207.03 130.525c9.372-9.373 24.568-9.373 33.941-.001z" fill="currentColor"></path></svg></span></button> <!-- /wp:generateblocks/button --> <!-- wp:generateblocks/container {"uniqueId":"069f913d","backgroundColor":"#fafafa","isDynamic":true,"blockVersion":4,"variantRole":"accordion-content","spacing":{"paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","marginBottom":"20px"}} --> <!-- wp:paragraph --> <p>Accordion content.</p> <!-- /wp:paragraph --> <!-- wp:generateblocks/container {"uniqueId":"11cb370d","bgImage":{"id":"","image":{"url":"https://picsum.photos/id/237/600"}},"isDynamic":true,"blockVersion":4,"blockLabel":"accordion background","className":"accordion-bg"} /--> <!-- /wp:generateblocks/container --> <!-- /wp:generateblocks/container --> <!-- wp:generateblocks/container {"uniqueId":"2c2e6a88","isDynamic":true,"blockVersion":4,"variantRole":"accordion-item","useTransition":true,"transitions":[{"state":"normal","target":"accordionContent","customSelector":"","timingFunction":"ease","delay":"","property":"max-height","duration":0.25}],"accordionTransition":"slide"} --> <!-- wp:generateblocks/button {"uniqueId":"61727514","blockVersion":4,"variantRole":"accordion-toggle","buttonType":"button","display":"flex","alignItems":"center","justifyContent":"space-between","columnGap":"0.5em","sizing":{"width":"100%"},"typography":{"textAlign":"left"},"spacing":{"paddingTop":"15px","paddingRight":"20px","paddingBottom":"15px","paddingLeft":"20px"},"backgroundColor":"#ffffff","backgroundColorHover":"#ffffff","backgroundColorCurrent":"#fafafa","textColor":"#000000","textColorHover":"#222222","textColorCurrent":"#000000","hasIcon":true,"iconLocation":"right","iconPaddingRight":"","iconStyles":{"width":"0.8em","height":"0.8em"}} --> <button class="gb-button gb-button-61727514 gb-accordion__toggle"><span class="gb-button-text">Accordion title</span><span class="gb-icon"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 448 512" width="1em" height="1em" ariahidden="true" role="img" class="gb-accordion__icon"><path d="M207.029 381.476L12.686 187.132c-9.373-9.373-9.373-24.569 0-33.941l22.667-22.667c9.357-9.357 24.522-9.375 33.901-.04L224 284.505l154.745-154.021c9.379-9.335 24.544-9.317 33.901.04l22.667 22.667c9.373 9.373 9.373 24.569 0 33.941L240.971 381.476c-9.373 9.372-24.569 9.372-33.942 0z" fill="currentColor"></path></svg><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 448 512" width="1em" height="1em" ariahidden="true" role="img" class="gb-accordion__icon-open"><path d="M240.971 130.524l194.343 194.343c9.373 9.373 9.373 24.569 0 33.941l-22.667 22.667c-9.357 9.357-24.522 9.375-33.901.04L224 227.495 69.255 381.516c-9.379 9.335-24.544 9.317-33.901-.04l-22.667-22.667c-9.373-9.373-9.373-24.569 0-33.941L207.03 130.525c9.372-9.373 24.568-9.373 33.941-.001z" fill="currentColor"></path></svg></span></button> <!-- /wp:generateblocks/button --> <!-- wp:generateblocks/container {"uniqueId":"bf5a53db","backgroundColor":"#fafafa","isDynamic":true,"blockVersion":4,"variantRole":"accordion-content","spacing":{"paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","marginBottom":"20px"}} --> <!-- wp:paragraph --> <p>Accordion content.</p> <!-- /wp:paragraph --> <!-- wp:generateblocks/container {"uniqueId":"bf269f67","bgImage":{"id":"","image":{"url":"https://picsum.photos/id/137/600"}},"isDynamic":true,"blockVersion":4,"blockLabel":"accordion background","className":"accordion-bg"} /--> <!-- /wp:generateblocks/container --> <!-- /wp:generateblocks/container --> <!-- wp:generateblocks/container {"uniqueId":"927d90cb","isDynamic":true,"blockVersion":4,"variantRole":"accordion-item","useTransition":true,"transitions":[{"state":"normal","target":"accordionContent","customSelector":"","timingFunction":"ease","delay":"","property":"max-height","duration":0.25}],"accordionTransition":"slide"} --> <!-- wp:generateblocks/button {"uniqueId":"e0867fd7","blockVersion":4,"variantRole":"accordion-toggle","buttonType":"button","display":"flex","alignItems":"center","justifyContent":"space-between","columnGap":"0.5em","sizing":{"width":"100%"},"typography":{"textAlign":"left"},"spacing":{"paddingTop":"15px","paddingRight":"20px","paddingBottom":"15px","paddingLeft":"20px"},"backgroundColor":"#ffffff","backgroundColorHover":"#ffffff","backgroundColorCurrent":"#fafafa","textColor":"#000000","textColorHover":"#222222","textColorCurrent":"#000000","hasIcon":true,"iconLocation":"right","iconPaddingRight":"","iconStyles":{"width":"0.8em","height":"0.8em"}} --> <button class="gb-button gb-button-e0867fd7 gb-accordion__toggle"><span class="gb-button-text">Accordion title</span><span class="gb-icon"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 448 512" width="1em" height="1em" ariahidden="true" role="img" class="gb-accordion__icon"><path d="M207.029 381.476L12.686 187.132c-9.373-9.373-9.373-24.569 0-33.941l22.667-22.667c9.357-9.357 24.522-9.375 33.901-.04L224 284.505l154.745-154.021c9.379-9.335 24.544-9.317 33.901.04l22.667 22.667c9.373 9.373 9.373 24.569 0 33.941L240.971 381.476c-9.373 9.372-24.569 9.372-33.942 0z" fill="currentColor"></path></svg><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 448 512" width="1em" height="1em" ariahidden="true" role="img" class="gb-accordion__icon-open"><path d="M240.971 130.524l194.343 194.343c9.373 9.373 9.373 24.569 0 33.941l-22.667 22.667c-9.357 9.357-24.522 9.375-33.901.04L224 227.495 69.255 381.516c-9.379 9.335-24.544 9.317-33.901-.04l-22.667-22.667c-9.373-9.373-9.373-24.569 0-33.941L207.03 130.525c9.372-9.373 24.568-9.373 33.941-.001z" fill="currentColor"></path></svg></span></button> <!-- /wp:generateblocks/button --> <!-- wp:generateblocks/container {"uniqueId":"13342251","backgroundColor":"#fafafa","isDynamic":true,"blockVersion":4,"variantRole":"accordion-content","spacing":{"paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","marginBottom":"20px"}} --> <!-- wp:paragraph --> <p>Accordion content.</p> <!-- /wp:paragraph --> <!-- wp:generateblocks/container {"uniqueId":"95598d5c","bgImage":{"id":"","image":{"url":"https://picsum.photos/id/337/600"}},"isDynamic":true,"blockVersion":4,"blockLabel":"accordion background","className":"accordion-bg"} /--> <!-- /wp:generateblocks/container --> <!-- /wp:generateblocks/container --> <!-- /wp:generateblocks/container --> <!-- /wp:generateblocks/container --> <!-- /wp:generateblocks/container -->
The main points:
1. the top Relative Parent Container block has its Layout > Position set to Relative
2. in each of the Accordion Item > Accordion Content containers is the a Container Block with the background image. And that block has a CSS class of:
accordion-bg
Now add this CSS to the site:
.accordion-bg { position: absolute; inset: 0 0 0 50%; opacity: 0; } .gb-accordion__item-open > .gb-accordion__content .accordion-bg { opacity: 1; }
What it does is absolute position the backgrounds relative to the Relative Parent but just the the right side of the screen. And sets there opacity to 0 unless the accordion item is open.
Alexis822
Sorry for the delay, I was away for several days. Thank you very much David, that helps me a lot. And on mobile, if I want it to be underneath, I just have to play with the padding, right?
On mobile, you can:
1. Set the accordion width to 100%.
2. Add this CSS:
@media(max-width: 768px) { .gb-container-21677a7b:has(.gb-accordion__item-open) { padding-bottom: 300px; } .accordion-bg { inset: calc(100% - 300px) 0 0 0; z-index:-1; } }
is the parent container of the accordion, you can give it an additional CSS class eg.accordion-parent
, then replacegb-container-21677a7b
with it in the CSS. -
Alexis822
Ok thank you both very much
Glad we could be of help!
