Pikapower
Is it possible to create a template page?
I will leave a page example in the private information -
Some questions:
1. How are you going to use the template? By duplicating pages and modifying the content in the page editor? Or do you want the template to pull the data dynamically?
2. If it’s the latter, how are you planning to store the data?
Pikapower
The first one. The second would be great, but is at this time not affordable I think
In that case, it’s staightforward, you just build a page like this and duplicate the page and modify it.
GP is a theme, it controls the style of the global settings like header/footer/sidebars/content container/archives, etc, it does not have control over the detailed content of pages and posts.
You will need block plugins to build the content and layout.
1. For the 1st part which is a full width section with background image, you can use a block element – page hero.
2. You will need a block plugin to create the tab (Zekerheden & reviews) and accordion (the content of the Zekerheden tab).
note: Our block plugin — GenerateBlocks pro has both accordion and tab blocks, but it’s a paid plugin, you might be able to find free plugins for it.
