Anonymous
Hello guys,
I saw this post: https://generatepress.com/forums/topic/creating-an-upcoming-events-page-with-query-loops-date-handling/.
I have also got into the same situation. I have made a custom post type for my events. I want to show the events that are today or in the future after today. I saw ou guys are adding this in the future. I found the possibility to do it after today. I think this is the date that the activity is made and not the date i added with the ACF plugin. Also the date is not ‘after today’ but a static date.
Did you guys add something like this so i can show only the post that are after today? In a custom field where i have the date?
Or else do you guys know a workaround? If you have any questions please let me know.
Have a great day 😀
today, it requires some custom query args to be passed to the query loop.
The following PHP Snippet would do that.add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) { // Apply filter if loop has class: custom-event-query if ( ! is_admin() && ! empty( $attributes['className'] ) && strpos( $attributes['className'], 'custom-event-query' ) !== false ) { // Add meta_query to filter posts with meta value (date) greater than or equal to current date $query_args['meta_query'] = array( array( 'key' => 'my-custom-date', 'value' => date( 'Y-m-d' ), // Current date in 'YYYY-MM-DD' format 'compare' => '>=', 'type' => 'DATE', ), ); // Merge existing query_args with additional args for ordering $query_args = array_merge( $query_args, array( 'meta_key' => 'my-custom-date', 'orderby' => 'meta_value', 'order' => 'ASC', )); } return $query_args; }, 10, 2 );
Notes:
here thecustom-event-query
is the CSS class that you add to the Query Loops > Grid Blocks > Advanced > Additional CSS Classes field.'key' => 'my-custom-date',
and'meta_key' => 'my-custom-date',
we set the custom field name ofmy-custom-date
change that to the name of your custom field that holds the event date you want to filter by.Those args will list only posts on or after the
my-custom-date
and in that date order.The rest of your query parameters such as the Post Type and number of posts to display should be added to the block settings.
Anonymous
Hey @david,
Excellent this is exactly what i was looking for. Thanks for the information and the quick response!
Have a great day!
Awesome – glad to hear that!
