Playing around with the CSS grid functionality in Generateblocks (Display grid).Have some questions about it:
1. Is there some documentation about the CSS grid functionality in Generateblocks (Display Grid)?
2. Noticed I can set grid template columsn and grid template rows. But how do I span a block on multiple cells? See image example.Span block on multiple cells:
I know that I do that with custom css (see css below) but is built in into Generateblocks natively? How do I do that? And if not, are there plans to built that in (and maybe some more userfriendly way to like visually drag and drop design grids)?
Custom css:
.item1 { grid-area: 1 / 1 / 2 / 3; } .item2 { grid-area: 1 / 3 / 3 / 5; } .item3 { grid-area: 2 / 1 / 3 / 2; } .item4 { grid-area: 2 / 2 / 3 / 3; }
1. It’s a CSS builder, so it’s the same as Grid CSS. Here’s a guide for you:https://css-tricks.com/snippets/css/complete-guide-grid/
2. You can create a sub global style, something like this:
https://app.screencast.com/9qF4xUbx2zR4sSo you apply the global style for the parent container, then edit the global style, click the More button, click the +New button, you can create a new parent selector, in my example, I created a sub selector with class
grid-1-1
, then you can see the global style selector changes to.css-grid .grid-1-1
, then you can define the row and column for the sub global style selector.Hope that’s clear.
Nice that this can be done in Generateblocks.
One question about subselectors. Should the subselector be set to Display Grid? What is the Default option in this case?
No, the child of the Grid does not have to be
display:grid
.Just like the child of a flex container does not have to be
display:flex
.What is the Default option in this case?
If the display property is not specified in CSS, the default value depends on the element itself. Each HTML element has a default display value defined in the CSS specification.
Some common default display values for HTML elements include:
block
for elements like<div>
,<p>
,<header>
,<footer>
,<section>
,<nav>
,<article>
, etc. These elements typically start on a new line and take up the full width available.–
inline
for elements like<span>
,<a>
,<strong>
,<em>
,<img>
,<input>
, etc. These elements don’t start on a new line and only take up as much width as necessary.–
inline-block
for elements like<button>
and<select>
. These elements behave like inline elements but can have a width and height specified. -
Thanks. Interesting, nice to learn some new things.
