I want to display the author avatar below my posts. I am using a custom PHP function you have provided to replace WP gravatars with an ACF image field that contains my custom author image.
However, I am having an issue with both the GeneratePress dynamic images block as well as the GenerateBlocks image block with dynamic data.
The image uploaded is 150×150, but I want to display it smaller and with rounded corners. But no matter what CSS I set in the Block Editor (either activating “Make image rounded” or setting a border radius of 50%) does not have any effect in the frontend.
What am I missing? Thanks!
you will need to place the Image inside a GB Container, and set the Containers width and border radius to do that. As that function replaces the img HTML of the block.
Thanks, David. Just tried and the sizing works, but the border radius on the container seems to have no effect to the image inside.
Ah, on the Container Block you added, set the Layout > Overflow settings to hidden.
Ah ok, thank you 🙂
You’re welcome
