Hey,
I want to create a similar banner to the one in the private area. It should be visible both on desktop and phone and work the same. The design I can make myself but the functionality should be the same. -
what is the Functionality that you want to match ?
Hey,
The main function should be that you can close and open it.
Not sure what you mean by close/open it, I didn’t find it.
Can you explain some more?
Hey,
There is an arrow to close the CTA banner, if you press that one it hides a bit and you can open it again by pressing the arrow.
I see, that’s can not be done by CSS, it requires custom JS.
Hey,
I understand what about if you skip the functionality and only have a banner down there?
That’s easy.
1. You can create the banner in a block element – hook, use
before_footer
hook.2. Give the root container a class, eg.
sticky-bottom-banner
Adding CSS class(es): https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/3. Add this CSS:
.sticky-bottom-banner { position: fixed; bottom: 0; width: 100%; }
Hey,
Is it possible to make it smaller on desktop and then make it look better for mobile view.
What do you mean by smaller? Width-wise or height-wise?
It’s built with blocks, you should be able to adjust it in the block level.
And what do you mean by “look better on mobile view”? Do you have a mockup?
Hey, I figured it out however I can’t change background colors of my blocks when editing elements.
The background color is set to white for the parent container which has the
class.You can select that container and change the background color.
