nicolas
I have used this Generate Press in the past with a couple of different sites and have never had issues with formatting between desktop and mobile, however after setting up a new site on the desktop the mobile is trash. Is there a button or something to sync the two?
Hi Nicolas,
The padding values you have for your Container Blocks are too high, especially for mobile.
In the Block Settings of the Container Blocks, select the mobile icon at the top, and decrease the padding values in the spacing options. Reference: https://docs.generateblocks.com/article/spacing-options-overview/
nicolas
This didn’t change anything on the mobile view…
What was updated on Generate Press? I built another site about 3 months ago and did not have any of these issues.
The major change I see is not being able to select full or contained page widths and vertical alignment on the layout section of a block.
I can share screenshots if that helps…is there a way to use the old layout to enable these features?
the hero section of that site, select the Container Block, and in Sizing remove the
Widthvalue its currently set to 1500px which is overflowing the smaller screens
