ben2944
Hello
In a site under construction, I have a weird behavior with some a-link color : in the same paragraph, the colors are not the same. They don’t seem to be “highlight” and I don’t see a custom css code. May you help me on this please ?
that link has an inline style in its HTML.
See here:https://app.screencast.com/2dOHiG3y4tutG
Did you copy and paste the text from somewhere that may have contained that link color ?
ben2944
Yes indeed, I’m moving the site from Elementor to GP. Is there a way to modify this in “bulk” ? (because I think there are some others links like this …)
You could forcibly overwrite the inline style by adding link colors using CSS and the
!important
.inside-article a { color: var(--hover-link) !important; }
But ideally you should edit each links HTML and remove the inline style.
ben2944
Ok, thanks for the tip. Anyway, I will do the “ideally” way T-T … Thanks for your help 🙂
You’re welcome
