Philip Gledhill
Via the block inserter > patterns dialogue.
I’d like to disable the core block patterns.
So I only see GenerateBlocks patterns that I’ve added myself.I found this code, but I’m not a php expert, is this code safe to run? I tested it using the Code Snippets plugin you suggest and it appears to work OK.
https://wordpress.org/support/topic/feature-request-disable-core-block-patterns/
add_action(‘init’, function() {
remove_theme_support(‘core-block-patterns’);
});Also.
The code above removes the core block patterns.
BUT the core post patterns still display via the block inserter > patterns dialogue.Is there a way to disable the core POST patterns too please?
that snippet is safe to run, its using the core functionality for disabling patterns.
And it should remove them for everywhere, do they still appear in the block inserter if you log out and log back in ? -
Philip Gledhill
No, they don’t reappear after logging out and in.
By post patterns I mean default WordPress query loop blocks under a tab called posts.
I think these are default WordPress patterns.
They display when using default WordPress themes (or GeneratePress) via the block inserter > patterns dialogue > (Scroll down to) Posts (patterns).
Is it possible to remove these too please?
Ah ok, so the Post patterns and the CTA patterns are linked to the core Query Loop and Social Icon blocks. So if you disable those blocks in the preferences those patterns should go away.
Philip Gledhill
Thanks David, I…
I went to Edit Page > Options (three dots top right) > Preferences (bottom tab).
Selected the Blocks tab: then disabled (unticked) – Widgets > Social Icons and – Theme > Query loop.Combined with the code snippet above, this made the Inserter > Patterns dialogue much cleaner, especially for non-techie end users.
Thank you.
Glad to be of help
