MalcolmMcAtee
Hello, I am trying to remove the Categories & Tags from the Entry Footer and Move them up top the Entry Header along with Post Date.
This is what I have so far:
add_filter('generate_footer_entry_meta_items', '__return_empty_array' ); add_filter('generate_header_entry_meta_items', function( $items ) { return array( 'date', 'categories', 'tags', ); } );
This works well, but I would also like to be able to include the default icons for categories and tags, and include some explanatory text around the values in the array. Perhaps something like this:
Posted on: March 15, 2024 • Categories: Cat1, Cat2, Cat3 • Tags: Tag1, Tag2, Tag3
Thanks, Malcolm
Hi Malcolm ,
Try this CSS
.entry-meta >* { display: block !important; } span.posted-on:before { content: "Posted on: "; } span.cat-links:before { content: "Categories: "; } span.tags-links:before { content: "Tags: "; } .entry-header .gp-icon { display: inline-block; }
MalcolmMcAtee
Thanks for your help.
This works, but I was hoping for a PHP solution. Mostly just for my education purposes, but maybe this is Generate press method?
— Maloclm
This is the simplest method 🙂
There are other methods:
1. PHP snippet:
add_filter( 'generate_inside_post_meta_item_output', function( $output, $item ) { if ( 'categories' === $item ) { return ' Categories: '; } if ( 'tags' === $item ) { return ' Tags: '; } if ( 'date' === $item ) { return ' Published on: '; } return $output; }, 50, 2 );
But you still need this CSS:
.entry-meta >* { display: block !important; } .entry-header .gp-icon { display: inline-block; }
2. Using a block element – post meta template, you can create your own layout and add the category/ tag
list of terms
via GB’s button block or GB’s headline block. -
MalcolmMcAtee
Thank you for your help.
Here is the complete PHP needed.
add_filter('generate_footer_entry_meta_items', '__return_empty_array' ); add_filter('generate_header_entry_meta_items', function( $items ) { return array( 'date', 'categories', 'tags', ); } ); add_filter( 'generate_inside_post_meta_item_output', function( $output, $item ) { if ( 'categories' === $item ) { return ' Categories: '; } if ( 'tags' === $item ) { return ' Tags: '; } if ( 'date' === $item ) { return ' Published on: '; } return $output; }, 50, 2 );
What do the 50 & 2 at the end signify?
.entry-meta >* { display: inline-block !important; } .entry-meta .gp-icon { display: inline-block !important; }
I switched the entry meta to inline-block as I want everything to sit on one line. I am still unable to make the default icons appear.
Thanks, Malcolm
the
50
is the priority
multiple function callbacks can be made from the same hook.
the priority allows you to set the order in which those functions are fired.
A lower number starting at0
will fire first.
Here we used50
to fire it later then any callback the theme may be making.the
2
is the number of expected arguments required by the filter hook.
ie.$output
&$item
Can i see the site so i can see whats up with the icons ?
MalcolmMcAtee
OK, from scratch.
Use this PHP:
add_filter( 'generate_header_entry_meta_items', function() { return array( 'date', 'categories', 'tags', ); } ); add_filter( 'generate_footer_entry_meta_items', function( $items ) { return array_diff( $items, [ 'categories', 'tags' ] ); } ); add_filter( 'generate_inside_post_meta_item_output', function( $output, $item ) { if ( 'categories' === $item ) { return $output . 'Categories: '; } if ( 'tags' === $item ) { return $output . 'Tags: '; } if ( 'date' === $item ) { return 'Published on: '; } return $output; }, 50, 2 );
And this CSS:
.entry-header .entry-meta { display: flex; column-gap: 10px; } .entry-header .entry-meta .gp-icon { display: inline-block; }
That should keep the icons before the labels before the category and tags
