souleclipse
My homepage is showing all the latest posts from all the categories.
However I want to be able to list down different show and display categories
Can you point me to the right direction on how I can display each category.
Example
==Latest Post==
{display all recent posts from all categories}
==Category A==
{display recent category A post excluding those in the latest post above}
==Category B==
{display recent category B post excluding those in the latest post above}
==Category C==
{display recent category C post excluding those in the latest post above}
EtcThe final outcome will be that the homepage we are able to show our top 3 categories and their individual post and all the most recent post we published.
i would suggest using the GenerateBlocks Query Loop block to display the posts on your homepage
https://docs.generateblocks.com/article/query-loop-overview/
There are some Patterns you can copy and paste to get started with:
https://generateblocks.com/library/?pattern-type=free&pattern-category=query-loop
In each query loop you can set its specific parameters eg.
Taxonomy
->Category
-> A term. -
souleclipse
Thank you!
Another one.
I like to display all the categories in one row and had an image display on top of it.
A visual example will be this https://imgur.com/a/qvUarBr
Please point me in the right direction.
Your help is greatly appreciated.
Hello there,
There’s no feature that can dynamically create such a section in GP.
You’ll need to manually create one through GenerateBlocks. I would suggest using a GB Grid Block for each category. Then, add an Image Block and a Headline Block.
References:
https://docs.generateblocks.com/article/grid-overview/
https://docs.generateblocks.com/article/headline-overview/
https://docs.generateblocks.com/article/image-overview/
