Greetings:
To improve user engagement on the website, I’d like to display featured image’s thumbnail along with previous/next post links at the bottom of every post.
Please guide how to accomplish this using the GP Premium theme.
Thank you.
Hi Sam,
This article should be helpful regarding this: https://docs.generatepress.com/article/block-element-post-navigation/
Do I need to be using block editor for this?
Please note that the website still uses the Classic Editor and I intend to keep it that way.
Please suggest a resolution keeping above in mind.
Thanks.
Yes, you would need to use the Block Editor.
Unfortunately, without using the Block Editor, you’ll need a custom code. This would be out of our scope of support though.
Thanks for your response.
I did some research. Will the code listed on following link work if added to functions.php?
Link: https://gist.github.com/generatepress/dc79fa83d8706f19365aa07ddd141cd3
You can give it a try.
The function doesn’t specify the size of the image though, you might need extra CSS or change the code a bit to add size attribute.
For example, you can change these 2 lines:
$prevThumbnail = isset( $prevPost ) ? get_the_post_thumbnail( $prevPost->ID ) : ''; $nextThumbnail = isset( $nextPost ) ? get_the_post_thumbnail( $nextPost->ID ) : '';
to:
$prevThumbnail = isset( $prevPost ) ? get_the_post_thumbnail( $prevPost->ID, array( 300, 200 ) ) : ''; $nextThumbnail = isset( $nextPost ) ? get_the_post_thumbnail( $nextPost->ID, array( 300, 200 ) ) : '';
So the output images will be 300px * 200px, feel free to change the values 🙂
