exceed94
Hello, I want to create a dropdown list to include external links on the website. Here are two examples in photos.
is it possible ?
1. create a new menu with the parent menu item and its children at appearance > menus.
2. assign this menu to secondary navigation.
3. Use this PHP code to create a shortcode
[secondary_navigation]
for secondary navigation:add_shortcode( 'secondary_navigation', function() { ob_start(); if ( function_exists( 'generate_secondary_navigation_position' ) ) { generate_secondary_navigation_position(); } return ob_get_clean(); } );
4. You can use this shortcode on pages.
exceed94
Thank you, but now the menu also displays at the top, how can I remove it ?
I added the shortcode in the footer but I’m not really fond of the formatting. : exemple : https://ibb.co/26rhKP1
I would rather display it this way :
thabks you
Go to customizer > layout > secondary navigation, set navigation location to
no navigation
.I would rather display it this way :
It requires custom HTML and JavaScript, custom JS is out of our support scope, however, it’s quite simple, so try adding the below HTML and JS via a custom HTML block, and modify the HTML code based on your needs:
<select id="myDropdown" onchange="navigate()"> <option value="disabled selected">Select an option</option> <option value="https://google.com/">Option 1</option> <option value="https://x.com">Option 2</option> <option value="https://facebook.com">Option 3</option> </select> <script> function navigate() { var dropdown = document.getElementById("myDropdown"); var selectedOption = dropdown.options[dropdown.selectedIndex]; if (selectedOption.value) { window.location.href = selectedOption.value; } } </script>
exceed94
Okay, so secondary navigation is no longer useful if I understand correctly?
correct.
exceed94
Thank you Ying. For the first method, is it impossible to use it in list form with css ?
The first method should show the dropdown list with a prant menu item and multiple children menu items.
exceed94
thabks
No Problem 🙂
