Alex117
Hi guys,
On a custom query only the first container does not display the title (heading w dynamic). Pls take a look.
Thank you
Is there any custom function involved for the headline block?
Can I have a look at the backend of the query loop block?
Alex117
Hi Ying,
It pulls the name from a custom field. But it’s been fine for a few months…
Login info below -
The custom field for that post is empty:
https://app.screencast.com/rrYElXaTIwLOq -
Alex117
That is strange. Is it possible to be some kind of a mix up with autosave or caching? I mean not GP but any ad platform conflict or smth?
Before checking here we’ve tried different field values and all. Clear cache, switch to draft, I mean a good 20 minutes focusing on this field. -
Alex117
Thanks Ying. I’ll check the logs. I think we may have a different issue.
You are welcome, hope you can get the issue sorted 🙂
