tiltin
Dear Support (attn. David),
Easy Table of Contents stopped showing on last 4 published posts on https://curvspace.com/
Older posts still show it like https://curvspace.com/hallway-lighting-ideas/
I checked the settings which look correct (unchanged/logins included).
Thank you.
Are you using h2/h3 headings on your new posts?
tiltin
Hi Ying thank you, not as far as I know just H1 as standard
I think the plugin pulls h2/h3 headings from the post content to form the TOC, which are not presented in your new posts.
I would recommend checking with the TOC plugin’s support.
tiltin
I’ll check it out thanks
No Problem 🙂
