Edit Footer from Starter Site “SOLAR”
  • krempel-und-co
    just set up a new page, imported the SOLAR-template from the Site Library.
    I can edit everything except the footer. I find nothing in the widgets and using the copyright-message-setting in the customizer does nothing. Where can I edit the footer?
    Kind Regards,
    Maurice
  • I would look in the Elements.
    The site footer is using block element – site footer, you can find it at appearance > elements > site footer.
  • krempel-und-co
    Thanks! I found it 🙂
