pnwcheryl
I found the following snippet in another post here to use the Rank Math primary category to show the primary category instead of all categories on some query loop blocks I set up:
/*add primary category for buttons for posts*/ add_filter('render_block', function ($block_content, $block) { if ( !is_admin() && !empty($block['attrs']['className']) && strpos($block['attrs']['className'], 'placeholder-for-primary-cat') !== false ) { $cat = false; $primary_cat_id = get_post_meta( get_the_ID(), 'rank_math_primary_category', true ); if ($primary_cat_id) { $cat = get_term($primary_cat_id, 'category'); if (!is_wp_error($cat)) { $primary_cat = $cat->name; $primary_term_url = get_term_link($cat); $primary_term_output = '<a class="primary-cat-' . esc_attr($primary_cat) . '" href="' . esc_url($primary_term_url) . '">' . esc_html($primary_cat) . '</a>'; $block_content = str_replace('primary-category-placeholder', $primary_term_output, $block_content); } } else { $categories = get_the_category(); $first_category = ''; if (!empty($categories)) { $first_category = $categories[0]->name; $first_category_url = get_term_link($categories[0]); $first_category_output = '<a class="primary-cat-' . esc_attr($first_category) . '" href="' . esc_url($first_category_url) . '">' . esc_html($first_category) . '</a>'; $block_content = str_replace('primary-category-placeholder', $first_category_output, $block_content); } } } return $block_content; }, 10, 2);
…it looked great. However, I found that, as I had implemented Rank Math recently, some older posts did not have a primary category yet and these posts all had a critical error until I removed the snippet.
Is there any way to edit this so that it will show either nothing or one category and not a critical error until I can get around to adding a primary category to all posts?
Try this one. I’ve made a slight adjustment to the existing code:
add_filter('render_block', function ($block_content, $block) { if ( !is_admin() && !empty($block['attrs']['className']) && strpos($block['attrs']['className'], 'placeholder-for-primary-cat') !== false ) { $cat = false; $primary_cat_id = get_post_meta( get_the_ID(), 'rank_math_primary_category', true ); if ($primary_cat_id) { $cat = get_term($primary_cat_id, 'category'); if (is_wp_error($cat)) return; $primary_cat = $cat->name; $primary_term_url = get_term_link($cat); $primary_term_output = '<a class="primary-cat-' . esc_attr($primary_cat) . '" href="' . esc_url($primary_term_url) . '">' . esc_html($primary_cat) . '</a>'; $block_content = str_replace('primary-category-placeholder', $primary_term_output, $block_content); } else { $categories = get_the_category(); $first_category = ''; if (!empty($categories)) { $first_category = $categories[0]->name; $first_category_url = get_term_link($categories[0]); $first_category_output = '<a class="primary-cat-' . esc_attr($first_category) . '" href="' . esc_url($first_category_url) . '">' . esc_html($first_category) . '</a>'; $block_content = str_replace('primary-category-placeholder', $first_category_output, $block_content); } } } return $block_content; }, 10, 2);
