You have it set in the Display rule settings to show on Info. I would recommend removing that.
Would you have a different Loop Template for Info? If so, yes, you need a separate code for that.
I want to use the same design for info and tip. So I set displayrule ‘info’ and ‘tip’. The problem is that ‘tip categories’ are output in ‘info category’. Is this php code wrong?
Could you share the link to the snippet for
[category_images]
Yes, it’s in the private tab.
Your Shortcode is set to output all Categories, not just sub-categories of the current viewed category.
To clarify, would you like to output all sub-categories of the current viewed category, or all the categories under info or tip depending on which of them or which sub-category is viewed?
I would like to display all the applicable subcategories according to primary navigation such as ‘info’ or ‘tip’.
See Yings reply here:
https://generate.support/topic/mirroring-a-certain-navidation/page/2/#post-90357
There she provides an example shortcode that returns children of the current parent.
