I design the standard Woo Shop start page with Elementor. Everything is displayed correctly in edit mode. Only when I set the page as store start page (Woo-settings-products), the Generate Press layouts are loaded. However, I do not want these. Header and footer is also from Elementor and Elementor Full Width. How can I change this? Thank you very much.
Can I see the page in question? And let me know what the exact issue is.
Please edit your first post on this topic, and add the site info into the private info field. It will only be seen by the support team.
The layout of elementor is not adopted. I have edited the store page https://www.kathis.at/cms/shop/ with elementor. But as soon as I set it as the store start page in woo, the design of generate press is adopted and the elementor widgets are also loaded incorrectly.
thank you.
Did you mean to set the Shop page as your homepage? Have you tried doing so by going to Settings > Reading and setting the Shop as the Homepage?
Hello, the Woo Shop start page is set under Woo – Products. This also works. However, this page that I created with Elementor is overwritten with the layout of Generate Press. I have used Elementor Full Width as the page layout. Therefore the layout of Generate Press should not be loaded. My question: How can I prevent this? I like to use the Woo Shop Start Page only with the layout from elementor?
If you go to Dashboard > Template > Theme Builder, you can see that the Product Archive is set to Draft. I think this is the layout you want to use, try publishing it.
Super thanks. now it works. I had completely forgotten about that 🙈
Awesome, you’re welcome!
